Old 02-24-2017, 11:04 AM   #34
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
Originally Posted by impstocker View Post
On a earlier post about getting the right intake gasket thickness so everything lines up, I just make my own out of gasket material using a regular available gasket as a template. I then use anti-seize compound as a dealer , also can remove intake and reinstall with same gasket.
Will Lamprecht
65 Impala I/SA 396/325
There's some good ideas there, Will. The gaskets I'll be using are meant to be cut-to-fit, as someone here suggested a while back. It turns out they fit the ports almost perfectly. But they have large elongated bolt holes, I presume to make them compatible with different port locations. I use gasket cement around the water passages only to glue them to the heads so they won't move while I drop the manifold on. I've been leaving the manifold side dry, but using some anti-seize on that side sounds good, I think I'll try that next time.
Dave Muller is offline   Reply With Quote
