Liked 431 Times in 224 Posts
I agree that I'd base the rear gear choice on finish line RPM. As for recovery coming off the stop, you can try a higher cruise RPM, coming off the stop in low gear, going on the stop later to get the car moving, etc.
S/ST 51 S/C 53 |
Liked 192 Times in 83 Posts
While it is true that finish line RPM plays a part, I was convinced a few years back by Eddie Jr, at Select Performance, to go to a 4.56 gear.. not only to enhance his converter set-up, but that I would be surprised by the charge coming off the stop.. I now have 2% to 3% slip in the converter at the top end, and that charge coming off the stop is awesome, and I go out the back door at approximately 7600 RPM with my 565.. I am only 2150 pounds also..
While I was a nay-sayer, until I switched from the 4.30, I doubt I'll go back.. while it slightly increased the RPM, I didn't seem to affect the MPH at all... |
#3 | |
Was there a measurable gain anywhere? Could you stay on the stop longer?
S/ST 51 S/C 53 |
Although I didn't mention MPH, I'm up between one and two.. also, I usually do stuff to try and take time out of the box.. not put more time in.. and I really don't like carrying 3.00 in the box either...
Liked 37 Times in 33 Posts
rob7181,
Going from the 4.10 your running to say a 4.33 would only be a 5% increase, but going to a 4.56 is going to be a 9% overall increase in performance. Plus you should pick up around 3mph. |
Liked 886 Times in 238 Posts
Like Charlie ,I run Select converters . I went to 4.56 gears from 4.29 in my Vette which weighs in at 2400# .
I picked up 2 mph with an increase of 250 trap rpm . converter efficiency went from 10% slip to 5-6%. AND very importantly , the converter temperature dropped way down when coming off the stop. Since Charlie's car is a '27 Roadster, one of the hardest cars to get MPH out of I'm not surprised by the lack of improvement in speed. I would defiantly recommend 4.56 gears in your car. Racers get too hung up on trap rpm's , if your engine is still pulling at the stripe ,let it eat !
^^^^^^this
#8 | |
Liked 52 Times in 32 Posts
SC 707Y |
