Old 12-11-2020, 08:15 PM   #11
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: Not for Nuthin' But Close!
Gm systems run a lot of pressure. When running a gm pump with a Mustang II rack you need to drop the pressure or you will blow the seals out of it. Borgesen makes a simple kit for this. Not to be confused with the flow reducers with a smaller hole in them. Gm also has a cold climate PS Fluid. I did not think it would slow the cars that much but your testing shows otherwise. Saturns have electric PS and have plate over pump hole, bolts rite on. I am told the VUE cams made more torque but they do not have the drive for PS. I have one if you want to try it. Tom
Tom Meyer 5240 SS Stock ???
