Old 12-11-2011, 08:28 PM   #21
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Re: lOOKING FOR SPEC'S 302/215@240
Originally Posted by Alex Denysenko View Post
Here you go Alan,
You just didn't look far enough.
http://www.ihra.com/uploadedFiles/Co...orList_831.pdf
Thanks Alex !
Much appreciated.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-13-2011, 01:04 PM   #22
goinbroke2
Liked 405 Times in 158 Posts
Thanks guys, I think mama is gonna get me a 750 holley for Christmas. In the rule book it says any Holley carb , oem or aftermarket 750cfm. It doesn't specify vacuum or double pumper so I'll assume either is ok? (and is dbl pump as obvious as it looks or should I consider vac sec since this is an auto small block and 750 is pretty big)?
Old 12-13-2011, 03:42 PM   #23
ALMACK
ALMACK's Avatar
I keep looking at the factored HP of those 3 crate engines.
The 270 hp is factored @ 250....only 10 more than the 215 @ 240 hp engine plus the 270 uses a larger lift cam, and better heads.
However, the 285 hp is factored at 255 hp. I do not have any literature about the 285 engine combo. ( I would love to see a scanned print copy of that 285 )
It seems to me the 270 or 285 would be a better choice to start with, maybe ?? Larger lift and better heads.
I/PS '95 Mustang GT
Old 12-13-2011, 05:20 PM   #24
Chris1529
Liked 70 Times in 29 Posts
most power can be made with the 270. GT40 P heads are better.
I run the 285 motor. original GT40 heads, .480 lift roller cam 1.6 RR. Same motor that came in 1993 Mustang Cobra minus the 1.7 roller rockers. (Factory B303 cam) I actually ran the B303 cam for a few years.
Other than the heads and cam lift, I believe the bottom end of each engine is the same as production 302's.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 12-13-2011, 08:00 PM   #25
ALMACK
ALMACK's Avatar
Thanks Chris for clearing that up.
The text in the the description for the 270 hp just says "GT40" so I was thinking they were Cobra 5.0 GT40 heads.
I/PS '95 Mustang GT
Old 12-13-2011, 08:42 PM   #26
Brandon Peterson
Car#-Driver(Opp'nt)-RT-----ET-- Speed-----Car#-Driver(Opp'nt)-RT-----ET-- Speed
972 Jamie Holston 2922 Amanda Justice
E1 ****WINNER**** 0.033 11.834 107.70 -0.044 11.196 119.07
H/SA Dial: 11.85 (+/-): -0.016 L/CM Dial: 11.28 (+/-): -0.084
Qualified: #56 11.931 -0.519 #4 11.305 -1.245
Justice went red.
this is our old car we sold back in march....it is the 270/250 hp, the GT40P heads are the better head and choice for a good easy cobo we tried both...the 40P'S flowed better than the regular 40's did....
when Olin set the record in M/CM at the ROCK a few years back he had the GT40P heads on his car saw them myself also...we actually ran quicker but didnt care about setting a record that weekend no points for records anymore means no point to do it anymore
Brandon Peterson is offline   Reply With Quote
Old 12-14-2011, 12:21 AM   #27
G PETERSON RACING
Alan the 270/250 uses the gt40p heads, the 285/265/255 uses the gt40 heads. The gt valve train refers to valve size as being the gt40 valves. As you can see that our 95 Mustang that we sold to Justice's is a top qualifier with 270/250 engine. It has stock crank, eagle rods, ross NHRA-IHRA stocker pistons, 750 DP holley, Victor Jr. intake, and gt40p heads with a good valve job. The short block for both engines are the same except for the cam lift. As my son Brandon said we have tried both and the 250 is a better combo.
Help this helps. Gary Peterson
G PETERSON RACING is offline   Reply With Quote
Old 12-14-2011, 02:40 PM   #28
ALMACK
ALMACK's Avatar
Thanks Gary.
That's good to hear that the 270 has more cam lift and better heads.
It looks like the 270 is the way to go for a carbed/automatic class car.
Thanks for the info.
I/PS '95 Mustang GT
Old 12-15-2011, 06:14 AM   #29
goinbroke2
I'll second the thanks!
GT-40P heads were the ones put on v-8 explorers right? I don't imagine you can buy them new anymore?
Old 12-15-2011, 05:02 PM   #30
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
I run the 302 215/240 HP crate motor in my Probe. This is the Explorer crate engine. It has the GT40P cylinder heads. This engine was available from Ford Racing back around 2000.
Here are the specs that were sent to IHRA:
This is from the 2000 Ford Racing catalog:
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
