Old 01-10-2013, 05:53 PM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: Dual caliper rear brakes
Wade,
I sent you a PM
Thanks
Jeff Lee 7494 D/S '70 AMX
Old 01-10-2013, 07:23 PM   #12
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Originally Posted by Wade_Owens View Post
Sean, you can stack the brake pressure by pumping the brake pedal, holding the line loc, and repumping the pedal, then releasing the button before rolling all the way in. Problem is, it still only gives the front more pressure and that's not generally where its needed. I can slide the front tires by doing this because I dont have enough rear pressure. After you get it all figured out, you can stall the right converter VERY high with the std 2 front, 2 rear setup. Believe me, I chased it for awhile.......
Wade
I figured it had to be the auto cars, as with a stick all you need is enough front brake pressure to not roll, the less the better. Thanks for the explanation.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-10-2013, 09:07 PM   #13
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Dual caliper rear brakes
Several years back I put aerospace disc brakes on our Nova. I went with dual calipers on the back for more holding power when staging. It was the best thing I ever did. The car went from really having to push the brake pedal hard to stage at 3000 to where with just a little pressure on the pedal I can take It up as high as I dare without it trying to creep at all. The only problem I then had was that the master cylinder didn't have enough volume to have a good pedal on the first pump.I fixed most of the problem by going to a big bore (11/8) master cylinder.It then had good brakes on the first pump but It was still about 3/4 of the way down. ( Not good for finish line braking) I finally put a 2lb residual valve in the brake line going to the back brakes and now I have a pedal nice and high. The back discs don't seem to have any more drag than they had before. Hope this might help someone. Bill
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 01-11-2013, 08:58 AM   #14
201250
201250's Avatar
Bill THANKS for sharing that info!!!!!!!!
TC
201250 is offline   Reply With Quote
Old 01-11-2013, 01:43 PM   #15
Rob Petrie E395
Liked 216 Times in 77 Posts
How are you guys plumbing your brakes? If you look at the Aerospace brakes instructions for plumbing dual rear calipers. It looks like they are saying to hook the front and rear ports together with a tee's. Are you guys doing it this way? I am sure it works but what happens if a line breaks. Seems like you would have no brakes instead of weak brakes.
http://aerospacecomponents.com/image...ons/dualpl.pdf
