#11 |
Liked 16 Times in 10 Posts
al my engine builders told me if u wanta burn a piston put some cheap gas in it! Its a crazy world we live in and NHRA tech is amoung them!
#12 |
That's a tough deal for sure. Do they normally check fuel in the later rounds when it's not a heads up run? Those last two rounds were some tight packages, especially the final!
4878 SS/GA 66CHEVY II |
#13 |
Liked 175 Times in 78 Posts
I should not say anything here since I get confused easier that I use to
I have a 2/12 gallon red generator gas can and a clear 5 gal fuel jug Hind sight is always easy - I have done some pretty dumb things in the last few years Things - I do not think I did 5 years ago That said - it is easy to make mistakes - hard to correct them Just have a few drinks and move on Some will kill me for this but - if you have an x-wife blame her - she would expect it Ron
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
#14 |
Liked 59 Times in 13 Posts
Dumb questions here -
Does Bertozzi have to check fuel and weigh when reinstated? Does Jared get to keep the semi round money? |
#15 |
Simple Mistake. Bertozzi caught a break, because he got drug that round. Jared and Bobby are a win waiting to happen. I have to race them at bracket races and they're tough customers. Great guys and consider them good friends.
Little trivia, but his brother Derrick won the first "No Electronics" Wally at the Div 4 ET Finals in 1995. |
#16 | |
From the EPA: Oxygenates are fuel additives that contain oxygen, usually in the form of alcohol or ether. Oxygenates can enhance fuel combustion and thereby reduce exhaust emissions. Some oxygenates also boost gasoline octane. The Clean Air Act requires use of oxygenated gasoline in areas where winter time carbon monoxide levels exceed federal air quality standards. Without oxygenated gasoline, carbon monoxide emissions from gasoline-fueled vehicles tend to increase in cold weather. Winter oxygenated gasoline programs are implemented by the states. The links below provide information about oxygenated gasoline, winter oxygenated gasoline areas, oxygenates (such as ethanol and MTBE), and health effects testing of oxygenates. Basically pump gas that has been oxygenated has qualities that are similar to those banned fuels unacceptable to NHRA. Since field testing is not able to decipher the exact recipe's used in the fuel being tested, if it a fuel check reveals certain properties, it's no good. Now, proper field testing is a whole 'nother story.
Jeff Lee 7494 D/S '70 AMX |
#17 | |
Guest
Posts: n/a
#18 |
Had some not pass. Sat over the winter and was to weak.
#19 |
Liked 54 Times in 18 Posts
If you have an ex wife or two you've made bigger & more expensive mistakes then just gas in the wrong jug
#20 |
Liked 4,379 Times in 502 Posts
I would think no one gets to advance unless Anthony stayed behind and got checked. I don't think you can allow someone to go back to his or her trailer and then have them come back for a fuel and weight check. Brian Worner may be able to help out on this one, he was reinstated after his opponent came up light on the scales in a heads up 3rd round run they had.
