#11 | |
Liked 43 Times in 29 Posts
Mark Ruset 2048 STK |
#12 | |
Chad Rhodes 2113 I/SA |
#13 |
Mark
I had the "Push through the beams problem (2500rpm on 2 step)" as I struggled to get 750lbs., brake pressure with my hand controls. I changed my MC to a 1.030 bore piece and increased my pedal ratio to 7.4:1. Wah lah, 1200+ psi pressure with hand controls, and no more pushing through the beams. Using your leg would probably bury the gauge on my car.
Peter Ash 6100 STK |
#14 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 Last edited by HandOverFist; 11-03-2013 at 12:36 PM. |
#15 |
Liked 279 Times in 68 Posts
Those 2piston fronts are for a really light car, 2400lbs or less. I have never seen them on a stocker. We have 4wheel aerospace on both my car and Andrew's and have had no problems. I can hold my car at 4000 plus rpm's on the starting line.
Greg Hill 4171 STK |
#16 |
None the less, they are already on the car and I will give them a chance. I don't envision using anywhere near 4000rpm on the starting line.
Rich Taylor I/SA - 321 |
#17 | |
Liked 90 Times in 29 Posts
#18 |
Greg that just what I wanted to hear, both cars are very competitive and I'm sure if there was a better product out there you would use it
#19 |
Thanks Jody for the reply, I am still using the OE style master cylinder, there within is part of my problem. I will be changing the master cylinder when I do the disc conversion
#20 | |
From what others have posted, sounds like you really need to get the right sizing of calipers and parts if you choose to go the disc route, not the super light stuff. I was not convinced that the weight saving over the 9 1/2" drums was worth the considerable cost, especially considering the starting line issues some have mentioned , just my experience, hope it works out for you... Grant Eldridge E/SA 6650 |
