Old 12-20-2015, 07:54 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Cylinder head milling
Anyone got a good handle on how much to mill per cc.
Ford 302 head to be exact.
Thanks
Mike Graham is offline   Reply With Quote
Old 12-20-2015, 08:21 PM   #2
pmrphil
Liked 348 Times in 152 Posts
Default Re: Cylinder head milling
Depending on chamber size to start with, the smaller ones (60-62) usually around .006 per cc
Phil Molski
PMR Performance
S/C 1623
Old 12-20-2015, 08:30 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
There is a formula for this. Read this link and do the measurements and calculations. Each time you shave 1cc out of the chamber it changes it's configuration and you should do the calculations all over again for the next cut.
Since combustion chambers have a different shape depending on the casting family it's hard to make a generalized statement.
http://www.eatonbalancing.com/blog/2...1cc-reduction/
There's a chart that will put in the ballpark at the link.
Dale
Dale Shearon
68 Mustang 6394
Old 12-21-2015, 10:22 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
most of time from .006-.008 will be close to 1cc on most heads.
Mike Taylor 3601
Old 12-22-2015, 05:13 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Most accurate way to know how much to mill is to assemble the valves in the head, set it with combustion chamber up on a stand or braced so that the surface is perfectly level. Then pour the amount of combustion chamber volume into each chamber and measure to the surface of the liquid with a depth mike. Record the depth measurement for each chamber and you can average the amount to mill off the surface. No guessing and you can get it where you want in one cut.
Old 12-23-2015, 03:03 PM   #6
Mike Graham
Dale
The formula worked perfectly. Thanks
Old 12-23-2015, 03:48 PM   #7
Ed Wright
Ed Wright's Avatar
Makes too much sense to do it this way. LOL
Ed Wright 4156 SS/JA
Old 12-23-2015, 04:07 PM   #8
Mike Taylor 3601
I had never thought of that,have always cut carefully and check,will save a little time. Thank's Dwight
Mike Taylor 3601
