Old 04-23-2017, 06:54 PM   #11
Liked 10,812 Times in 2,247 Posts
Default Re: 69 Chevelle AA/SA 10.04 at 125mphat Spring Nats
If NHRA starts rounding the numbers, then NHRA will be changing the shipping weight. If the number is 8.4999999 it should be 8.49, just use the first two places to the right of the decimal point. Its so easy even a hillbilly can do it.
Old 04-23-2017, 07:17 PM   #12
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Larry -
Except that the factors on the Class Guide sheets are rounded now. It's just that the odd cases where the number is on the break is it a concern. Also, I have class guide sheets for 1969 Chevrolet back to 2002 and they are all 8.50 for that combination.
Old 04-23-2017, 07:32 PM   #13
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
I'm building the 396/375 to run B with mine, the way I see the sheets the 427/425 is natural A. 427 would be one heavy old ride in B
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 04-23-2017, 07:34 PM   #14
M Brand 505B
Liked 31 Times in 10 Posts
The 8.49 was recently brought to NHRA's attention hence the change. I would assume NHRA rounds down even if its 8.499 like they do on class weight ex. 3449 is 3445. The rule book doesn't seem to cover how weights and indexes are rounded though except for adding/taking away HP and that is rounded up ex 2.15 is 3.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 04-23-2017, 07:50 PM   #15
Adub464Q
Adub464Q's Avatar
Liked 478 Times in 91 Posts
We can't sneak anything past you guys on here!
Yes, I was running a 69 chevelle with a 427/425 combo, with aftermarket heads rated at 435 hp. The car is owned by Will Carrell out of Oklahoma and he's done an awesome job building this combo. Regardless of the head, the factor is still done with the advertised hp (425).
The shipping weight is 3611. When doing the math,
3611/425 = 8.496....hence the dilemma. I did the math and Will brought it to NHRA's attention that it should be a natural A car, similar to what Larry mentioned above. Pat was in agreement that the excel sheet was incorrectly rounding the factor up. He adjusted the excel sheet this week prior to us entering the national event on Thursday. We did not enter the class until the sheetvwas changed online.
This was all done because AA at a minimum of 3430 is much more attractive than C at 4000+ lbs. Not to mention that it is much more safe.
If anyone would like to discuss this, PM me and l will give you my phone number.
Also for the record, the car is really cool and wheelie fun to drive.
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
Old 04-23-2017, 08:05 PM   #16
Casey Plaizier
I'd really like your phone number.
Casey Plaizier is offline   Reply With Quote
Old 04-23-2017, 10:08 PM   #17
MR DERBY CITY
Liked 8,048 Times in 1,529 Posts
Nicely played, BRAVO.....
Old 04-23-2017, 11:07 PM   #18
Liked 1,874 Times in 422 Posts
Austin, congratulations to both you and Will, and thank you! Good luck racing that car.
By no means was I complaining, questioning, or saying you did anything wrong, Austin. You got them to move that combination to a natural A combination, finally, and I'm glad you did. Thanks again.
Old 04-23-2017, 11:23 PM   #19
Adub464Q
Adub464Q's Avatar
No problem, just explaining the process we went through for everyone. Like I said, we didn't turn the tech card in until it was fully changed online, even after getting a verbal confirmation.
Also, I will be back in the duster soon enough, we just had an issue come up with that car.
You know you've done something when Jason line looks at the car and says "What combo runs AA in a chevelle?"
Austin Williams
3 SG
464Q STK SC
Old 04-24-2017, 07:28 PM   #20
Cameron Collins
Let's see a picture of this bad *** car
Cameron Collins is offline   Reply With Quote
