Old 05-19-2008, 09:43 PM   #1
ronn brigham
Cool Radial slick vs. Bias-ply slick
I am returning to dragracing after a long time away from the sport.I will be running in Stock Eliminator in a stick shift car.What are the differences in the use of a radial vs. bias-ply slick.
I will appreciate any and all input.
Ronn Brigham
ronn brigham is offline   Reply With Quote
Old 05-19-2008, 10:41 PM   #2
SSDiv6
Default Re: Radial slick vs. Bias-ply slick
Ronn Brigham
I can be incorrect...but, as I understand, stick shift cars are running bias-py and not radials in Stock Eliminator
Old 05-19-2008, 10:54 PM   #3
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Radials will not work in a stick car. Bias ply or the Mickey Thompson stick shift tire is what you need to use. Have fun!!!!!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 05-26-2008, 05:29 PM   #4
n2oracer
How about radial vs bias with a transbrake?
n2oracer is offline   Reply With Quote
Old 05-26-2008, 09:50 PM   #5
james schaechter
Joe is right on. Buy a set of Mickey Thompson 29.5 stick tires. Make sure yo uget the right ones. They make a 29.5 bias ply for an auto and a radial 29.5. This wont be a problem if you buy then at a MT trailer, but if you order from a 3rd party make sure they send the right ones. I know Larry Hodge sells them and will know what you need. The part # is 3056ST. The MTs last and are quick. Welcome to stick stock racing! Lot's more fun! Don't forget the clutch pedal switch.
James Schaechter 3163 STK
Old 05-26-2008, 10:43 PM   #6
Dave Casey
Liked 804 Times in 168 Posts
I agree on the tires, and the 3056st tires are a good choice. 10 years ago or so when my camaro would make l or m stock (stick), I used some radials on a few record runs.The car would loose a few hundredths in 60 and gain that and a couple more back down track. It was a net gain but the car was heavy and it won't work at faster et's nowadays in my car.
Dave Casey 1330 STK
Old 05-27-2008, 10:25 AM   #7
Bill Pomponi
I agree with Dave Casey. The MT 3056st is the correct tire for stick cars.
Bill Pomponi is offline   Reply With Quote
Old 05-27-2008, 12:14 PM   #8
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
With tubes and screws or without?
Eric Merryfield 1883 STK
Old 05-27-2008, 01:50 PM   #9
Doug Domm
Liked 84 Times in 21 Posts
What is the differance between the 3056 and the 3056st Mickey? Is it is stiffer sidewall or ???? How will the 3056st work on an automatic car?
Doug Domm is offline   Reply With Quote
Old 05-27-2008, 07:19 PM   #10
Stick Racing
3056st tire is a M5 compound. 3056 is a L8 compound. St tire also has less tread-as all manual transmission tires. The compound is harder which wears less.
I always run the 3066st tire. This tire is no longer available. I tried the 3066 instead. Threw them away after 12 passes. Bought the 3056st. Right back where I was before, 'cept a few more rpms...
Andy Stone 1102 B/S
Stick Racing is offline   Reply With Quote
