When replacing the stock valves on E7TE heads, what is the prefered choice of brand? Any pros/cons on valve seals? Anything else to think about? Not looking to break any records, just want to use the proper parts and make it work as good as possible.
Thanks! Joakim, Sweden |
#2 | |
Liked 1,598 Times in 583 Posts
Intake: P/N 11572-8 Exhaust: P/N 11523-8 Ferrea: Intake: P/N F6261 Exhaust: P/N F6260 There are differences of opinion in the use of valve seals; myself, I prefer to use them. Hope this helps. |
#3 | |
Liked 2,638 Times in 440 Posts
Bill Seabrooks - superfan1 |
Liked 370 Times in 101 Posts
Also check Manley exhaust valves, they are also too big.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 239 Times in 94 Posts
Do those have the exhaust keeper groove in the higher position like the intakes or older 289-302 valves?
Liked 1,943 Times in 584 Posts
I have been using REV Valves with no failures. They are much more reasonable than Ferrea and more user friendly. They didnt charge me to cut down the valves for my engine.
Racing Engine Valves 954-772-6060
Mike Pearson 2485 SS |
Thanks to everybody for your input on this!
Another question on this subject is if sleeves should be used in the heads when replacing the valves? |
I assume your are talking of bronze liners in the guides. Yes, they can be used; make sure the machine shop has the appropriate reamers and knows how to do it.
Yep, you are correct, those are the ones I mean. You say they can be used, but is it necessary? Any pros/cons on that?
