Old 12-30-2008, 01:48 PM   #11
mtkawboy
Liked 54 Times in 18 Posts
Default Re: Ford guys..........E7 heads question
Please define untouched
mtkawboy is offline   Reply With Quote
Old 12-30-2008, 04:46 PM   #12
Notch1320
Larry's heads... (I beleive) were untouched as in straight out of a stock car... with 150,000 miles!!! I am sure he will chime in, and clarify this, but "untouched", or fresh, either way, very impressive!!!.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 12-31-2008, 08:44 AM   #13
Evan Smith
Liked 115 Times in 5 Posts
Years ago I ran 11.80s with the H.O. combo, but John Presing has been 11.50s at 113 mph using E7 heads. It's hard to compare NHRA and NMRA cars because NHRA cars get slicks and a better drivetrain, but NMRA cars (I believe) can use flat-top pistons and they can run with a much smaller combustion chamber. Either way it's impressive to run 11s with those heads, especially when there are lots of cars with aftermarket aluminum heads that don't run as well.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 12-31-2008, 10:11 AM   #14
Geddes
Guys,
Thanks for the input here. I had no intention to compare my thrown together engine, just curious....for fun.
specs:
150,000 miles from an 89 GT (sitting under the bench since '99)
PB Blaster used as the rings were freed, to turn it over. Took a few days of soaking.
E7 heads with plenty of carbon
B-303 camshaft (retarded 4 degrees)
Crane valve spring kit
Cobra 1.7 roller rockers
Edelbrock Performer RPM
575 cfm Demon
Mac 1 5/8" headers
air pan sealed to hood
McLeod diaphragm clutch
GF 5R Transmission, clutchless 3.19 low gear
4.86 gear in the 9 inch
launched @ 6200
shifted @ 6000
crossing at 6200 (tongue hanging out)
3025 pounds
28X10.5 Tires
11.69 and 112 mph. This was a hurry up deal. We thought it would run 12.30 or so.
Thanks,
Larry Geddes
Geddes is offline   Reply With Quote
Old 12-31-2008, 01:44 PM   #15
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Larry: what gear were you running and what RPM did you go thrugh the traps at? I have been struggling to get mine to work right all year, and wandering what gear to use witht he new setup
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-31-2008, 03:41 PM   #16
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Evan
NMRA F/S guys run a 58cc head, but none the less, the things they do with a stock combo, as awesome
Evan
I got every mag of your stocker buildup!!!!
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 01-01-2009, 12:41 PM   #17
Geddes
Freddie,
4.86 gear
6200 rpm in the lights
Old 01-01-2009, 05:11 PM   #18
Freddie
Freddie's Avatar
Larry: thanks... are you still running the Kuntz motor? Car looked great in Chicago.
Old 01-01-2009, 05:13 PM   #19
Chris1529
Liked 70 Times in 29 Posts
Larry, have you tried the cam at different centerlines?
4 deg retarded seems alot to me for only running 6200 RPM.
Do you use all 5 gears? Is 5th gear 1.1 ?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
