Would a sbc dart block be legal in a Modified Stock class such as SS/AS, BS, and CS?
4878 SS/GA 66CHEVY II |
Liked 880 Times in 311 Posts
The way I read the rule book... NO Check with someone @ NHRA to make sure. It might be an area that has changed since the GM/auto industry downturn (read that availibilty of replacement or superceded parts) I have read where GM Pro Stock racers are trying to get non GM parts approved to be able to keep racing. I also am aware that there are no more V-6 Bowtie blocks, (heads too) and there is a movement by a couple of Comp racers to get Dart to build a replacement that is approved by NHRA.
Adger Smith (Former SS) Last edited by Adger Smith; 07-09-2009 at 06:17 AM. Reason: sp |
No it would have to have a gm part number. The same with the heads
No prep is king |
Thats the way I read it too. Thanks for the replies.
Liked 109 Times in 32 Posts
On a slightly different note, whats the difference between modified (AM, BM) and modified stock (AS, BS)?
I'm pretty sure in AM, BM you can run two carbs instead of one in AS, and BS
Yes, on the carb diff. Modified Stock mandates 850 & 750 single carb, depending on class. I think the transmissions don't have to be a corp match either & the rear tire size rule is dropped. It states ANY size that fits the orginal outer wheel well. There is no limitation on hood scoop either. Any type rear spoiler in Modified instead of fatory type in Modified stock..The firewall can be modified a little in Modified. might be more
Adger Smith (Former SS) |
#8 | |
Liked 10 Times in 1 Post
chrysler or gm is ok
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
Liked 1,436 Times in 299 Posts
You can only run a 4 speed in AS,BS, CS. In Modifed, you may run a 5 speed. Of course that is highly discouraged since the antique lameass weight break is still in effect for automatics so you don't see much call for that these days.
James Schaechter 3163 STK |
