#11 | |
Liked 237 Times in 126 Posts
Coming soon to a red light near you... Dale
#12 | |
Liked 163 Times in 53 Posts
I have ran all 3 and the victor jr intake on my SBF...in your application the air gap is what you need... if it was a stickshift id go with a victor jr
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#13 | |
Jeff
Street legal 64 Falcon Sprint with 410W ![]() Stock - Super Stock fan |
#14 |
Correction: Stall on the converter is 3000-3200
Dale
#15 |
That sounds better.
Why the solid roller cam? A friend in Albuquerque runs a hydraulic roller in his low 11 sec. 347 Fox body. Much easier to maintain. Sets the valves at the start of the season then leaves it alone. Car is street legal too. I could get you the numbers if you'd like. Jeff
#16 |
Liked 285 Times in 87 Posts
#17 | |
Air Gap is more expensive than Stealth, but at this point in the build a hundred bucks is a drop in the bucket. Can anyone verify that the Holley dash number carb 0-80540-1 (600 cfm) is the legal one in GT. It's specs match the one listed for the 68 Cougar in the blueprint thing. Accepted Products states "All Holley dash numbers are accepted unless otherwise noted" Thanks for all the input. Dale
#18 | |
Jeff
Street legal 64 Falcon Sprint with 410W ![]() Stock - Super Stock fan Last edited by Mile High; 07-08-2014 at 11:20 AM. Reason: misspelled |
#19 | |
Dale
#20 | |
Liked 1,604 Times in 583 Posts
Have you talked to any racers that run the class as regards to what is allowed or are you making your own interpretation of the rule book? If you show up to race in Super Stock GT with the particular Holley carburetor you are referring to, you will be sent home before you even make your first run! You either run the original OEM carb as shown in the spec sheet or run the approved carb shown in page 126 of the current NHRA accepted products list. The accepted replacement carbs are shown in the link below: http://www.nhra.com/userfiles/file/N...edProducts.pdf |
