Old 08-12-2020, 08:48 AM   #1
drgrcr68
Liked 4 Times in 3 Posts
Default pro trans advice
would like to speak to anyone that has purchased pro trans 350 thanks 6084360282
drgrcr68 is offline   Reply With Quote
Old 08-13-2020, 01:30 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: pro trans advice
I'm about to.
Have a Proflite and have had several other ProFlites through the years.
Have you seen a gear ratio chart?
Adger Smith (Former SS)
Old 08-13-2020, 08:23 AM   #3
drgrcr68
no i have not, just curious if and how much car picks up
Old 08-13-2020, 02:46 PM   #4
Race Clean
Liked 129 Times in 53 Posts
Originally Posted by Adger Smith View Post
I'm about to.
I have, there right around 60 combinations of gear ratios that I saw if you are asking!
Stop global whining
Race Clean is offline   Reply With Quote
Old 08-13-2020, 09:00 PM   #5
Gregg Luneack
Liked 225 Times in 30 Posts
My Nova wagon pick up 12 hundreds.
Gregg Luneack is offline   Reply With Quote
Old 08-13-2020, 10:24 PM   #6
S/ST 3040
S/ST 3040's Avatar
From gear selection or less friction?
S/ST 3040 is offline   Reply With Quote
Old 08-14-2020, 12:56 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
What was in it prior to the pro trans? Poweglide?
Mike Pearson 2485 SS
Old 08-14-2020, 06:57 PM   #8
Gregg Luneack
It was a 208 Powerglide, the advantage is it does not
pull down the RPM on the gear change like a PG.
You do not need to over rev the 1-2 shift like a PG.
You have a smaller RPM window to work in.
Old 08-14-2020, 07:07 PM   #9
Mike Pearson
I would like to make that change with my car. I figured it would be worth about .015. I like the glide because it is so durable and simple. Mine really struggles at the gear change.
Old 08-14-2020, 07:23 PM   #10
Gregg Luneack
Its hard to beat a PG as far as easy to work on
and reliability, but the ProTrans 904/350 is also
very reliable and easy to work on. Its hard to spend
the money but you wont be disapointed.
