Liked 4 Times in 3 Posts
would like to speak to anyone that has purchased pro trans 350 thanks 6084360282
Liked 880 Times in 311 Posts
I'm about to.
Have a Proflite and have had several other ProFlites through the years. Have you seen a gear ratio chart?
Adger Smith (Former SS) |
no i have not, just curious if and how much car picks up
Liked 129 Times in 53 Posts
I have, there right around 60 combinations of gear ratios that I saw if you are asking!
Stop global whining |
Liked 225 Times in 30 Posts
My Nova wagon pick up 12 hundreds.
Liked 1,940 Times in 584 Posts
What was in it prior to the pro trans? Poweglide?
Mike Pearson 2485 SS |
It was a 208 Powerglide, the advantage is it does not
pull down the RPM on the gear change like a PG. You do not need to over rev the 1-2 shift like a PG. You have a smaller RPM window to work in. |
I would like to make that change with my car. I figured it would be worth about .015. I like the glide because it is so durable and simple. Mine really struggles at the gear change.
Its hard to beat a PG as far as easy to work on
and reliability, but the ProTrans 904/350 is also very reliable and easy to work on. Its hard to spend the money but you wont be disapointed. |
