#21 | |
Liked 734 Times in 385 Posts
Remember it is not one size does the same for all. This is a 426 ci Chrysler with the same 0.06" offset. Bore = 4.25 Stroke = 3.75 Rod Length = 6.768 RPM = 6500 Wrist Pin Offset = 0.06 Actual Piston Stroke 3.75015962277 Cylinder Volume 53.200718 CI 871.803575 cc Engine Size 425.605745 CI 6974.428599 cc Crank Angle Piston TDC -0.39775244513 Piston BDC 179.29739772523 Stan |
#22 |
Liked 347 Times in 151 Posts
Wasn't the Boss 302 a dome piston? Can't put that in backwards.
Phil Molski PMR Performance S/C 1623 |
#23 |
Liked 142 Times in 51 Posts
No need to do that, any stocker can Submit their own piston for the class.
#24 |
Liked 54 Times in 33 Posts
#25 |
#26 | |
Turbo cars have a tendency to have low speed Pre ignition with much higher Combustion pressure.... But, I am here to gather ideas and have looked further into detonation. I can see how they can be confused with one another. Thank you for the response. I do look forward to the NGK heat range 9 plug to test. Last edited by MoJo Risen; 09-02-2021 at 12:15 AM. |
#27 | |
Liked 22 Times in 14 Posts
Help us slow ones out a little bit. What exactly am I looking at and how would it affect power? Rick Thomason GTOMayhem |
#28 |
When you add wrist pin offset a number of thinks happen. The piston and the crank rod journal are not ATDC and BBDC at the same time. Now based on which way you have the offset decides if piston TDC is before or after crank rod journal TDC. Another thing that happens is all 4 cycle are not long 90 degrees each. 2 become less and 2 become more. Again which 2 do what is based on where the offset was placed.The is also a very very small change in stroke and displacement. (For inline engines where you can move / offset the crank center line these can be larger).
Stan Last edited by Stan Weiss; 09-02-2021 at 08:07 AM. Reason: Added Graph |
#29 |
Liked 705 Times in 219 Posts
In light of all this study of the laws of physics, what does the installation of an offset pin piston have on piston to valve clearance ? Sounds like a way to close up excessive clearance on one valve while opening it up on others. Or, like so many things out there, is it significant or just one more gnat to swat at?
#30 | |
Within a normal range of piston pin offset the piston travel curve does not change very much from centered. So if you are using piston TDC there should be almost no difference in VTP clearance because of wrist pin offset. Stan PS Above I am talking about if you degree the cam. If someone just installs the cam dot to dot (crank rod journal TDC?) There will be more of a change in VTP clearance from the offset over centered pin. Stan Last edited by Stan Weiss; 09-02-2021 at 11:09 AM. Reason: Added PS |
