Old 09-01-2021, 01:41 PM   #1
MoJo Risen
Liked 148 Times in 54 Posts
Default Re: Spark Plug Heat ranges, what gains have you made?
Originally Posted by Ralph A Powell View Post
I now for a fact on the Boss 302 it was worth 10 hp as I was at Dyno the night we run it.
Thats approximately 2.5% gain?
There is more potential HP in a corrected Piston pin offset.
I'm glad we all know now that NHRA DOES NOT TECH THIS FEATURE.
MoJo Risen is offline   Reply With Quote
Old 09-01-2021, 03:52 PM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Remember it is not one size does the same for all. This is a 426 ci Chrysler with the same 0.06" offset.
Bore = 4.25 Stroke = 3.75 Rod Length = 6.768 RPM = 6500
Wrist Pin Offset = 0.06
Actual Piston Stroke 3.75015962277
Cylinder Volume 53.200718 CI 871.803575 cc
Engine Size 425.605745 CI 6974.428599 cc
Crank Angle Piston TDC -0.39775244513 Piston BDC 179.29739772523
Stan
Old 09-01-2021, 05:49 PM   #3
pmrphil
Liked 397 Times in 153 Posts
Wasn't the Boss 302 a dome piston? Can't put that in backwards.
Phil Molski
PMR Performance
S/C 1623
Old 09-01-2021, 08:00 PM   #4
MoJo Risen
No need to do that, any stocker can Submit their own piston for the class.
