Old 02-09-2009, 05:47 PM   #9
Donnie Moore Jr.
Donnie Moore Jr.'s Avatar
Send a message via Yahoo to Donnie Moore Jr.
Default Re: Leaving off a button in Stock
Originally Posted by 67ss View Post
First of all, if I am not mistaken I thought it was legal to leave off a button and 2 step in stock, but not a transbrake. Maybe this is just an NHRA rule and not legal in IHRA. At any rate, with some bracket tracks going No Box instead of footrbake and not thinking my car would be suited to a transbrake leave I was thinking about this. If this is something anyone has played with how do you mount the button. I have heard of them being on the foot brake, but can you use just any old button to do it this way since you will be applying quite a bit of pressure to the butto? Or, is it just as easy to let go of the button with your finger and the footbrake at the same time? How much RT can be gained by leaving off a button and a low side pill vs. off just the footbrake?
U need to check with the track you are running at because I have had problems in the past trying to do that "no box" means no electronics to leave starting line including 2steps... just letting you in on past experinence
Donnie Moore Jr.
SS/GA 9401
Donnie Moore Jr. is offline   Reply With Quote
