Old 01-09-2013, 11:12 PM   #1
201250
201250's Avatar
Default Re: Dual caliper rear brakes
Thanks for the info. So is the procedure to pre-stage, press the brake pedal to a given pressure, engage a 2-step set at an RPM low enough to be able to go WOT off the line? I see a lot of stock elim cars bouncing back and forth during the staging process, but they seem to leave against the 2-step.
201250 is offline   Reply With Quote
Old 01-10-2013, 12:10 AM   #2
Ed Wright
Ed Wright's Avatar
You do not want more brake on the rear than the front. Good way to swap ends if you have to lock them up. I have single Aerospace calipers all the way around. I can stall it well over 3000 RPM with the foot brake with no problems. You may have the wrong master cylinder, or wrong pedal ratio.
Ed Wright 4156 SS/JA
Old 01-10-2013, 01:43 PM   #3
201250
201250's Avatar
Thanks Ed ................good input. My experience has been in SS so leave off the tranny brake and let her eat. Now with getting back into stock eliminator need to learn new ways of staging/leaving.
TC
Old 01-10-2013, 01:57 PM   #4
Ed Wright
Ed Wright's Avatar
TC
I let FJ Smith to the brain work for me. :-)
Just bought his master cylinder kit and firewall brace for my model car, and followed the enclosed instructions for re-drilling my pedal.
Old 01-10-2013, 01:58 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Maybe I am missing something, but if you are using a LL it is only active for the front brakes and staging the car. What would it matter if you had 8 rear caliper brakes on the rear? Just a curious 3 pedal racer.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-10-2013, 02:45 PM   #6
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Sean
Sean, you can stack the brake pressure by pumping the brake pedal, holding the line loc, and repumping the pedal, then releasing the button before rolling all the way in. Problem is, it still only gives the front more pressure and that's not generally where its needed. I can slide the front tires by doing this because I dont have enough rear pressure. After you get it all figured out, you can stall the right converter VERY high with the std 2 front, 2 rear setup. Believe me, I chased it for awhile.......
Wade
Old 01-10-2013, 04:27 PM   #7
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
whoooooaaa! i get it. forget i said anything.
i thought the new craze of 6 and 8 piston calipers where for down the top end.....but not so much it seems. i want to try this now, damn snow....i can bring the rpm up to 4800 now, should able to hit mid 5k with more brake. i still only launch at 3400 during the bracket race, but qualifying would be more fun!
Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Last edited by Ian Hill; 01-10-2013 at 04:36 PM. Reason: didnt get it...but now i get it! LOLOLOL
Ian Hill is offline   Reply With Quote
Old 01-10-2013, 05:53 PM   #8
Jeff Lee
Jeff Lee's Avatar
Wade,
I sent you a PM
Thanks
Jeff Lee 7494 D/S '70 AMX
Old 01-10-2013, 07:23 PM   #9
Sean Marconette
Wade
I figured it had to be the auto cars, as with a stick all you need is enough front brake pressure to not roll, the less the better. Thanks for the explanation.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-10-2013, 09:07 PM   #10
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Dual caliper rear brakes
Several years back I put aerospace disc brakes on our Nova. I went with dual calipers on the back for more holding power when staging. It was the best thing I ever did. The car went from really having to push the brake pedal hard to stage at 3000 to where with just a little pressure on the pedal I can take It up as high as I dare without it trying to creep at all. The only problem I then had was that the master cylinder didn't have enough volume to have a good pedal on the first pump.I fixed most of the problem by going to a big bore (11/8) master cylinder.It then had good brakes on the first pump but It was still about 3/4 of the way down. ( Not good for finish line braking) I finally put a 2lb residual valve in the brake line going to the back brakes and now I have a pedal nice and high. The back discs don't seem to have any more drag than they had before. Hope this might help someone. Bill
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
