#11 |
Wade,
I sent you a PM Thanks
Jeff Lee 7494 D/S '70 AMX |
#12 | |
Liked 275 Times in 76 Posts
Sean
#13 |
Liked 169 Times in 53 Posts
Several years back I put aerospace disc brakes on our Nova. I went with dual calipers on the back for more holding power when staging. It was the best thing I ever did. The car went from really having to push the brake pedal hard to stage at 3000 to where with just a little pressure on the pedal I can take It up as high as I dare without it trying to creep at all. The only problem I then had was that the master cylinder didn't have enough volume to have a good pedal on the first pump.I fixed most of the problem by going to a big bore (11/8) master cylinder.It then had good brakes on the first pump but It was still about 3/4 of the way down. ( Not good for finish line braking) I finally put a 2lb residual valve in the brake line going to the back brakes and now I have a pedal nice and high. The back discs don't seem to have any more drag than they had before. Hope this might help someone. Bill
Bill Bogues 4696 STK |
#14 |
Bill THANKS for sharing that info!!!!!!!!
TC |
#15 |
Liked 216 Times in 77 Posts
How are you guys plumbing your brakes? If you look at the Aerospace brakes instructions for plumbing dual rear calipers. It looks like they are saying to hook the front and rear ports together with a tee's. Are you guys doing it this way? I am sure it works but what happens if a line breaks. Seems like you would have no brakes instead of weak brakes.
http://aerospacecomponents.com/image...ons/dualpl.pdf |
