Old 07-17-2013, 09:26 PM   #1
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Low travel hydraulic stocker lifters
Ineed some input on the "best' or the right way to adjust these things. I'm not sure about the way they "feel" or the noise they make when I adjust them. bye the way, they are Trend lifters for a small block chevy. Any Input will be appreciated.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 07-18-2013, 09:07 PM   #2
G Anderson
Liked 4 Times in 3 Posts
Default Re: Low travel hydraulic stocker lifters
Only have had these for 3 yrs-But this is how I've been doing it--------
I push down on the back side of the rocker with my finger while sliding a .015 feeler gauge between the rocker and the valve and adjust lock nut for the "feel" that I like ! Sooner or later I will try setting them looser or tighter ?
G Anderson is offline   Reply With Quote
Old 07-19-2013, 08:14 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
G Anderson,
That is the same method I use.
I say if you tighten your lash to .003 or .005 you'll see and improvement.
I use the in closing/ex opening (honda method)in case need explanation,intake is almost closed set the ex ex barely opens set the intake if engine is warm usaully start with setting ex valves,if you go through all ex or all in engine does'nt have to rotate alot if rotating by hand just make sure you rotate engine the direction it runs.
Mike Taylor 3601
Old 07-19-2013, 12:58 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,181 Times in 972 Posts
Originally Posted by Mike Taylor 3601 View Post
G Anderson,
Mike Taylor 3601
Bingo!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
