Old 09-05-2017, 11:26 AM   #11
ZenzenRacing
Liked 53 Times in 17 Posts
Smile Re: 350 Stocker timing
He has a good idea !!
ZenzenRacing is offline   Reply With Quote
Old 09-05-2017, 05:46 PM   #12
Liked 10,852 Times in 2,254 Posts
Default Re: 350 Stocker timing
Did you check tdc with the head off, to see if balancer and pointer agree?
Old 09-05-2017, 06:15 PM   #13
ZenzenRacing
Yep, I will be checking TDC ! With 41deg tonite I hope there's time for testing this year yet!!
Old 09-05-2017, 08:13 PM   #14
Ed Wright
Ed Wright's Avatar
Originally Posted by ZenzenRacing View Post
Thanks guys, we run C-11 in both cars.
Most of those I have worked with liked 34 degrees on C11.
Ed Wright 4156 SS/JA
Old 09-05-2017, 11:52 PM   #15
Jim Hanig
Liked 99 Times in 49 Posts
Ed, less rimming when you use c11? In 10-1 compression
Old 09-06-2017, 08:56 AM   #16
Ed Wright
Ed Wright's Avatar
My LT1 likes less timing with C11. Runs faster on C11. Don't see how less timing could be a bad thing. Likes 35 on the dyno on C11. We don't race dyno. Runs more MPH with 36 degrees in high gear. GM calls it 10.5-1.
Old 09-09-2017, 09:33 PM   #17
goinbroke2
Liked 405 Times in 158 Posts
Damper slipped, pointer wrong, light messed up...really though, numbers mean nothing, just find what it likes and run it there. More efficient chambers like less timing in general but for a carbed 350, make a couple passes trying a little each way, what it likes is the correct amount.
Old 09-10-2017, 10:55 AM   #18
Ed Wright
Ed Wright's Avatar
He/we need a "number" for a reference when putting it back together next time.
