Old 09-18-2008, 04:02 AM   #1
87gt50
Default Stock legal valves for 5.0 mustang?
When replacing the stock valves on E7TE heads, what is the prefered choice of brand? Any pros/cons on valve seals? Anything else to think about? Not looking to break any records, just want to use the proper parts and make it work as good as possible.
Thanks!
Joakim, Sweden
87gt50 is offline   Reply With Quote
Old 09-18-2008, 09:53 AM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Stock legal valves for 5.0 mustang?
Thanks!
Joakim, Sweden
Manley:
Intake: P/N 11572-8
Exhaust: P/N 11523-8
Ferrea:
Intake: P/N F6261
Exhaust: P/N F6260
There are differences of opinion in the use of valve seals; myself, I prefer to use them. Hope this helps.
Old 09-20-2008, 02:09 PM   #3
Superfan1
Superfan1's Avatar
Liked 2,637 Times in 440 Posts
Smile Re: Stock legal valves for 5.0 mustang?
Originally Posted by 1664SSJA View Post
I like Ferreas, but if you need to have them cut down, have Ferrea do it. I think they charged 5 dollars a valve, and machine shop would be more. REMEMBER to DOUBLE CHECK the valves for size after they are cut, no matter who cuts them down.
Read the last sentence again. VERY IMPORTANT.
Especially after what happened to Evan Smith.
Bill Seabrooks - superfan1
Old 09-20-2008, 05:55 PM   #4
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Also check Manley exhaust valves, they are also too big.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 09-21-2008, 10:14 PM   #5
Tom P
Liked 239 Times in 94 Posts
Do those have the exhaust keeper groove in the higher position like the intakes or older 289-302 valves?
Old 09-22-2008, 12:30 AM   #6
SSDiv6
I do not know about the Ferreas, however, the Manley's don't since they are for rail type rockers.
Old 09-22-2008, 03:47 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
I have been using REV Valves with no failures. They are much more reasonable than Ferrea and more user friendly. They didnt charge me to cut down the valves for my engine.
Racing Engine Valves 954-772-6060
Mike Pearson 2485 SS
Old 09-23-2008, 03:28 PM   #8
87gt50
Thanks to everybody for your input on this!
Another question on this subject is if sleeves should be used in the heads when replacing the valves?
Old 09-23-2008, 03:39 PM   #9
SSDiv6
I assume your are talking of bronze liners in the guides. Yes, they can be used; make sure the machine shop has the appropriate reamers and knows how to do it.
Old 09-25-2008, 05:02 AM   #10
87gt50
Yep, you are correct, those are the ones I mean. You say they can be used, but is it necessary? Any pros/cons on that?
