Old 02-28-2009, 11:09 PM   #34
DonatoEng
Liked 8 Times in 5 Posts
Default Re: 4 cylinder cars?
Sounds like a good combination. What size throttle body are you running ?
Are you planning to run a log manifold on top of the PT lower ?
If so, you end up with the throttle body opening aiming to the side of the car. I would run the Mitsu head with the intake on the back side and an intake similar to the PT. That way the intake opening is aimed to the front of the car.
DonatoEng is offline   Reply With Quote
