#21 | |
The 290 doesn't look too bad at 210hp. I wasn't sure about the 4 speed. You can run it it L, seeing you already have a bar (cage?). I really don't see the 6 cylinder running the index in Q/Stock. How about it, Tom Goldman?
#22 |
Liked 780 Times in 194 Posts
#23 | |
Liked 8 Times in 7 Posts
thought the 2bbl 290s were 200 horse and the 4bbl's were 225.... i could be wrong. |
#24 | |
Liked 100 Times in 45 Posts
Dwight,CRS is a bitch isn't it? Ed
Former NHRA #1945 Former IHRA #1945 T/SA |
#25 | |
Liked 883 Times in 237 Posts
.....Tom
#26 | |
Not exactly a 10 cent car ..as Billy would say..
#27 |
yep, you're right on both counts, i didn't read ALL the page and i prolly wouldn't like the 6 in it BUT, as i said, it might be fun until i get a 290 built.... and i'm leaning towards the 4bbl version and it HAS to be a 4 speed....
#28 |
Under FRAME it allows joining of factory front / rear subframes in Stock. No mention of roll-bar.
It is interesting that AMC provided subframe connectors on the '68-'69 Rambler. I've been told it was for the V-8 only. From what I've seen, a 343 Typhoon V-8 Rogue with a factory T-10 4-speed and 3.54 rear gears (or steeper) could hold it's own in a street race back in the day! I would guess headers, a Holley 750 w/ an aluminum intake and 4.10 gears with 7" slicks could add up to a high 13 second street car. I once had a '69 AMX that had a bone stock 343 with a 4-speed, 3.54's and street tires. It was good for 96 MPH in the 1/4.
Jeff Lee 7494 D/S '70 AMX |
#29 | |
it was a 6 cyl/auto car.... |
#30 |
Liked 8 Times in 5 Posts
I'd go with the 290, 4bbl combo. Don't forget to check the supersession listing on heads and block before you build the engine.
