Old 03-21-2009, 10:38 PM   #21
treessavoy
Liked 4 Times in 4 Posts
Default Re: 71 plymouth scamp build
Originally Posted by 71plymouth View Post
i live in northern florida. which would be the best to run? IHRA or NHRA? at the gator nats last week i saw a couple of CM cars running.
If you look at the IHRA major events you will see that they are all waaay up north, if you don't mind traveling then they are a good bet with a crate motor car.
Old 03-22-2009, 10:35 AM   #22
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Originally Posted by Sean Haning View Post
It would probably have to be a SS GT car.
Cratemotor is a stock class, how would it fit NHRA Superstock GT? Stock and superstock are on two different ends of the bookshelf. Ya they might seem the same in some cases but couldn't be any more different in the real world. Crate motors arn't even accepted in superstock and not just because they are allowed to run a 750 with a choke plate and tower. A Q-Jet has to have the choke plate and tower in superstock as well so really the carb has nothing to do with weather or not its allowed in superstock or not.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 03-22-2009, 03:41 PM   #23
71plymouth
71plymouth's Avatar
i could run the ssssa races and some of the D2 ihra events.
71plymouth is offline   Reply With Quote
