Old 05-23-2009, 10:12 PM   #1
Alan Warman
Default Need Help 200 Metric Question
I need help, I'm quickly running out of time,I'm trying to get my car going for the Dallas race next weekend. The problem is that I bought a used Dynamic Metric 200, it was built on a Chevy case and I needed a BOP case.So when I changed out the case I freshened it up, there was nothing unusual, just some scorched clutches.Now that I have it installed, there is no hi gear. When I lift checked it, I could not feel it go into third gear, but when I pulled it back into second, I could feel second re-engage. Then I let it down and test drove it, and sure enough, when I shifted into third, it would just flare up. I pulled it back out and checked every thing. The only thing I could find was that I had put the wrong check ball in the front pump, as well as the fact that the Chevy case was built on a lock up unit, and the BOP case is a non-lock up unit. Thinking that must have been the problem, I fixed it and reinstalled. STILL NO THIRD GEAR!!! HELP!!!
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 05-24-2009, 04:26 AM   #2
Default Re: Need Help 200 Metric Question
Did you plug the governor passage in the case?
Old 05-24-2009, 01:20 PM   #3
Alan Warman
Mark
I did not plug the governor passage,because the other unit did not have it plug ed.So I went out and plug ed it off,still no third.Put in a governor and a new governor cover,still no third.
Alan Warman
STK 4107
Old 05-24-2009, 02:05 PM   #4
Is it a reverse pattern then?
Old 05-24-2009, 02:14 PM   #5
Alan Warman
No Sir,I was told it was a forward patten valve body.Before I bought it I talked to Frank Lupo,and he said the early ones he made were all forward pattern.
Alan Warman
STK 4107
Old 05-24-2009, 02:23 PM   #6
Seems to me the governor passage would have to be plugged on the case side, above the valve body.
Otherwise ,you're going to have to trace the fluid from the VB to the servo and direct.
Call me : 602 -769-0346
Old 05-27-2009, 06:07 PM   #7
F/SA TSM
first time with you guys a got problem register my self to the forum. my advice is that you miss the check ball in the pump. Th 200 need that ball to have 3rd gear .
F/SA TSM is offline   Reply With Quote
Old 05-27-2009, 09:33 PM   #8
Alan Warman
F/SA TSM
That is the first thing I checked,built enough of these in the eighties to remeber that.
Alan Warman
STK 4107
Old 05-27-2009, 09:49 PM   #9
F/SA TSM
just in case sorry
Old 05-27-2009, 10:49 PM   #10
Alan Warman
Don't be sorry,I am taking all advice on this problem.It looks like we traced the problem to the valve body.And welcome to Classracer.A lot of good people on here.
Alan Warman
STK 4107
