Old 10-30-2009, 01:32 PM   #11
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Default Re: Hoosier 30" Radial Designation
Originally Posted by Andrew Hill View Post
The thing is, 92.5" circumference tires are a lot closer to 29.5" diameter than they are to 30", so it would make sense to call them 29.5/9.0/15. I'm surprised Hoosier hasn't already figured this out.
Another thing I wanted to say before is you can CALL them whatever you want,but PLEASE don't change ANYTHING about the tires.I have run into this before,where a tire made by a certain manufacturer works very well and then they CHANGE the compound or something to try and "improve" them.
The Hoosier tires that are currently made DO NOT need ANY "improvements" in my opinion.They work great!
Old 10-30-2009, 02:52 PM   #12
david ring
david ring's Avatar
we've run the 92.5 on my comp car (it's a four cylinder) and the 94 inch tire would be a big problem in terms of gearing, so yeah, different numbers would be great.
david ring is offline   Reply With Quote
Old 10-30-2009, 04:49 PM   #13
Lyn Smith
Liked 984 Times in 198 Posts
Thumbs up Re: Hoosier 30" Radial Designation
Bruce ,yes this would be a great Idea to change the sidewall size to the correct designation.I have sent you a PM on this subject. thanks for your concern.
Old 10-30-2009, 08:56 PM   #14
Billy Baker
Liked 2 Times in 1 Post
Sounds like a good idea to me..
Billy Baker 3187 G/SA
3586 SS/LA
Billy Baker is online now   Reply With Quote
Old 10-31-2009, 01:58 AM   #15
Marvin Robinson
Marvin Robinson's Avatar
I would definitely like to see the change in the designation of the tires to avoid confustion. I also agree that no change in the actual tire compound or construction is necessary, the performance is phenomenal!!
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 10-31-2009, 07:19 PM   #16
George Mirza
Great idea!
Common sense, oh yea, this is drag racing.
George Mirza is offline   Reply With Quote
Old 11-01-2009, 03:15 PM   #17
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
I never understood why they weren't called/ labeled that to begin with. Good idea.
Old 11-01-2009, 06:17 PM   #18
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
Originally Posted by tiremaster View Post
A lot of times at the track when someone comes to to buy tires and are asked which size are you running they are not sure on 30x9 or 9x30 I have to ask the rollout or they go back and check. Just trying to make it easier.Or would this just confuse matters even worse?
Pardon my ignorance but what is the difference between 30x9 and 9x30? I always thought it was the same just worded differently.
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 11-01-2009, 09:29 PM   #19
tiremaster
Liked 7 Times in 4 Posts
That is why I am trying to get it changed. The 30/9 is 92.5"cir. and the 9/30 is 94".
tiremaster is offline   Reply With Quote
Old 11-05-2009, 12:08 PM   #20
Redlight
I also think it is a good idea.
Make sure the changes are in BOLD letters.
But, no matter what you do, you will start getting calls, "what ever happened to size XXXXX?".
Oh, a DOT version of the tire would be nice for those that want to run in other classes/events.
Redlight is offline   Reply With Quote
