Liked 20 Times in 15 Posts
If it is, you just made life a whole lot easier. I can not find this info.
Liked 6 Times in 5 Posts
I don't think a 318-4 manifold is gonna be legal. They were 1978 and newer and were Thermoquad only. I think you'll need a manifold with the "little AFB" pattern.
I believe Paul Wong and Bill Bushmaker have experience with these engines. As Jeff said, if the Edelbrock is legal, that will help a lot! |
Paul Wong is running the LD4B. It was approved for the 273 mid to late last year. It's probably worth a 25 HP improvement...
Jeff Lee 7494 D/S '70 AMX |
Liked 1,110 Times in 304 Posts
Back in the early 70`s, I had a daily driver 65 Valiant Signet 2 dr HT with a factory 273/235HP & 4 speed.It had an iron intake manifold, but I later installed an Edelbrock LD4B, but to make it fit, I had to hog out the intake bolt holes, and used flat washers with the bolts. I remember seeing some other LD4B intakes with Chrysler part numbers on them, but mine did not. Was that a D Dart thing, or a over the counter MoPar sold intake?
#5 | |
Even AMC had a factory p/n cast into the Edelbrock R4B. In fact, I think all the "4B" series by Edelbrock had a factory p/n cast into them at one time (Buick, Pontiac, AMC, Chrysler...)
Somebody really snookered NHRA on this ![]()
Liked 100 Times in 45 Posts
Jeez,too bad you can't put one on a stocker.Especially with a Holley on top.
Former NHRA #1945 Former IHRA #1945 T/SA |
