Old 01-07-2011, 10:48 AM   #13
krugracing12
Default Re: Buy now and save
Most CO detectors sound off in codes that can be found in the directions. Keep in mind that any fuel fired appliances produce CO, stoves, refrigerators, heaters etc. The activation source may be coming from within your unit and the only way to be sure is to have someone take readings. If that is not available, the only safe thing to do is completely ventilate the unit and shut off all appliances until they can be tested.
krugracing12 is offline   Reply With Quote
