Old 08-15-2011, 04:27 PM   #11
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: 1968 Dodge Darts (Factory SS/EA 440's)
Mungo Jerry,
1968 Numbers;
1968 Dodge Dart GTS 440,,,,,
Weight;,,,,,,,,,, #3208 lbs.
Engine;,,,,,,,,,,, 440/375HP
Wt/Hp,,,,,,,,,,,,,,8.55 wt/hp
Carburetor;,,,,,,Carter 750 AVS (1 11/16" x 1 11/16")
Compression;,10.1 -1 (flat top pistons)
Intake;,,,,,,,,,,,,,,,Cast Iron Dual-Plane / Low-Riser,,,, (Cast #2806178)
Heads:,,,,,,,,,,,,,,2.08 Intake / 1.74 Exhaust, Open chamber 79.5 cc's,,,, (Cast #2843906)
Camshaft;,,,,,,,,,.455 Intake Lift / .480 Exhaust Lift,,,, 268*/284* Duration,,,,46* Overlap
Cam Type;,,,,,,,,Hydraulic Lifters, Non-Adjustable rocker arms
1968 Class;,,,,,SS/EA (Super/Stock Only)
Dodge did not build enough cars to qualify for B/SA.
Automatic only cars,,,
Oddity,,,,,,there were only '6' 1968 Dodge Dart GTS 440 cars built at the time of the1968 NHRA Winternationals, yet they were legal entries,,,,
