Old 02-29-2012, 05:35 PM   #3
Chad Rhodes
Default Re: control arm bushings for 1st gen camaro
Originally Posted by 1320racer View Post
Global West, Afco and others. That said, the same can be accomplished by modifying poly graphite bushings by adding a zerk fitting, cutting a grease groove in the bushing and turning down the sleeve which is what I had on my Chevelle.
actually no it can't. The poly bushing will still deflect, albeit less than the stock rubber one. The Del-A-Lum style that global west sells will not and will still move just as free if not more so.
Chad Rhodes 2113 I/SA
