Old 05-30-2012, 10:18 PM   #1
Liked 1,874 Times in 422 Posts
Default Re: flex plate to converter spacers
Use thick AN type washers, or make your own with a lathe.
As mentioned elsewhere, make certain that the pilot of the converter extends well into the bore on the back of the crank shaft.
Old 05-30-2012, 10:34 PM   #2
FED 387
Liked 333 Times in 180 Posts
try TE-CO Union Ohio--they make xtra thick hardened washers usually for use in machine shops for machine tool holding but never the less they make them--- probably from 1/4 in dia up to 1 1/2 inch several thicknesses
Old 06-01-2012, 10:41 AM   #3
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: flex plate to converter spacers
Ace Hardware has an assortment of thick washers. I bought some for just that purpose. Not having the converter in far enough can result in the front pump drive lugs breaking off. I learned that the hard way last year.
