Old 12-12-2012, 10:46 AM   #20
lstanford
Liked 134 Times in 32 Posts
Default Re: HolBrook Racing Engines Makes History!...
Originally Posted by boster View Post
No disrespect to anyone but the part # is listed in the guide . I know Holbrook can read and the NHRA tech people could read the number on the head. I think we can all agree on that . Call it what you want but it was the wrong casting number for the head .
The Fact is that Holbrook did use the wrong head's when the numbers were clearly visible to everyone and went 1500 miles to try and set a national record with the wrong numbers on the heads. He did not get tossed , got no HP and the AHFS failed
Charlie, call me and I will give you someone who will tell you that people have set national records at opens and been sealed up to tear down later , got the hp, when they torn down they failed and the HP stayed on . This person is well known and a long time racer 30 plus years
The only point I'm trying to make is that there should not be a loop hole in setting a national record that circumvent's the AHFS system
Hats off to Jim Collins and company for checking those casting numbers
Let's try this for the sake of argument. What if all of the 50 2013 Cobra Jets and all of the 5.0 motors that Ford Motorsport sold had the same casting #'s that Chris had on his heads? AND what if after the run Chris was preoccupied trying to remember if he put ice in the beer cooler for the evening festivities and forgot to stop at the scales. This could be a real head scratcher for some of you guys. Get your facts before you try to expert this situation.
lstanford is offline   Reply With Quote
