#1 | |
Liked 46 Times in 4 Posts
My first teardown experience was at the same place (Mayo's AAmco transmission in Reynoldsburg) with Gary Russell. It was us, Matt Rover, and Howard & Greg Stanfield. Upon dis-assembling Gary's Q-jet, Dave Danish noticed a small baffle on the floor of the float bowl made out of the top of a Sucrets box. (Leroy Hoaglin did the carb) All Dave told Gary is to take it out. We all ate pizza that night too. |
Liked 54 Times in 18 Posts
A friend who shall remain nameless was tossed for class at Indy for having 1 TRW pushrod that somehow got mixed in with the 15 Ford pushrods. Dempsy Hardy got tossed for class at Indy because he didnt know to put the Pontiac head in the ice cooler before CCing the combustion chamber & came up 1/2 short. In the Junior Stock days cars would have so many vacuum leaks that the motors would hardly run. We once painted a steel Doug Nash Muncie 4 speed case silver after grinding all the Doug Nash letters off then wiping it with aluminum filings while the paint was wet. I love this post, it could go on forever
Liked 336 Times in 183 Posts
I remember a guy who also will remain nameless Div 3 racer was about to get pumped and the tech guy asked the racer which hole he wanted to do. He said I dunno # 3 or whatever it was so he goes thru the whole thing pulls the plug, screws the P&G adapter in and removes the rockers and turns the engine over pumps up to whatever it is supposed to be and the tech guy said you are good to go--- only one problem the other 7 cylinders were .060 larger than the one they pumped---he always pumped that same cylinder till somebody protested him and he had to pull the head and they measured both the bores and stroke!!!!!!! How do you say OOOPS?
I remember in the early 80's getting tossed for having a sponsor decal that was "too many square inches big". Yup that's correct, a decal that was TOO BIG! Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 99 Times in 21 Posts
I remember back in the early 80's my brother was running a 1958 Chevy wagon in IHRA Super Stock. It was a 283 econo modified piece with a 650 CFM Holly 2 bbl. Back then the head rules allowed only a port match with no polishing of the ports. The car always qualified well due to the soft index of the 2 bbl. (formula3) classes, that TRC prepped 650 Holleybflowed 730 CFM and was as quick as a 4bbl on the 283. We got pulled into tech at Darlington and was told to pull the intake, a header and two rockers and a plug. My brother and I were no engine builders and back then didn't have a clue but I mentioned to him that the exhaust ports didn't look legal. The floor of the ports on them 292 turbo heads looked pretty wide and flat from the casting line down and I was worried. The tech man (not Robert Leonard) done a visual of the heads and P&Ged the motor, and said looks good button it up. I told my brother "I hope that guy don't call little league ball games cause he can't see crap!. Don Jackson
