Old 07-03-2013, 03:55 PM   #11
GTX JOHN
Default Re: BBM/Hemi stocker oil pan
73 and 74 B Body is a Bear to find 6 quart that fits unless you move
engine back a inch or two. Anyone have any experience?
Old 07-04-2013, 01:41 AM   #12
Phillip marvetz
Phillip marvetz's Avatar
Originally Posted by Chris DeGidio View Post
1970.
Assuming that you have had it down the track what RPM are you turning it to?
2009 V/SA Record Holder
Old 07-04-2013, 12:55 PM   #13
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
68-7000 when we used to race it..why??
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 07-04-2013, 01:47 PM   #14
Phillip marvetz
Well because a Hemi needs to be spun over 8000rpm and I doubt a 5 quart pan has enough capacity. Also the 62-65 K member is different than the later model units which brings us back to the fact that Toms K member is going to have to be notched so the oil pan will fit therefore he should just get the larger capacity unit and done with it. This is assuming his car has the early K member still installed. It cost at least 20k to build one of these engines and I sure would not recommend he use a stock type 4-5 quart pan.
Tom, Please let us know what you end up using.
Old 07-04-2013, 06:31 PM   #15
Chris DeGidio
If it's a stock eliminator car,you can't run more capacity,and that's where I was going with this.
Nautilus Racing
Old 07-05-2013, 02:00 AM   #16
Phillip marvetz
Talking Re: BBM/Hemi stocker oil pan
Oh, Wow. I have no response for that.
Old 07-05-2013, 03:22 AM   #17
Jeff Lee
Jeff Lee's Avatar
There's a whole lotta Stockers that can go 8,000+/- RPM and they are supposedly using the factory pans per the rule book. And I don't see in the rule book that you can notch the k-frame because why would you need to if you were running the stock pan, per the rules?
And if 5 quarts isn't enough, the rulebook does allow the use of an Accu-Sump. Or maybe 3 quarts in the pan, 1 quart or so in the filter and 3 quarts in the Accu-Sump...
Jeff Lee 7494 D/S '70 AMX
Old 07-05-2013, 03:31 PM   #18
Chris DeGidio
Good.
Nautilus Racing
Old 07-12-2013, 01:45 AM   #19
Jeff Lee
Jeff Lee's Avatar
My bad....you CAN notch the k-frame for oil pan removal. Must re-enforce the area removed.
Old 07-16-2013, 08:39 AM   #20
Liked 10,835 Times in 2,252 Posts
Over fill the pan and use an accumulator to bring oil level down. My engine has never seen 8000 rpm, in fact I have a 9000 rpm tach. and the top third of it is never used.
