#12 |
Liked 225 Times in 88 Posts
Sounds like to diffrant problems which needs to be fixed . Low oil psi in the shut down and you will kill the motor . When you say you loose oil psi , it goes from what to what . What problem are you having with the trans. You could be over heating the trans by shutting off its oiling system and lose its cooling effects. Do you run and trans cooler ?
