Liked 10 Times in 7 Posts
Ok guys batteries died in car last race of the year, looking to replace in spring. Any recommendations of brand, type? Dual batteries here front/back
Liked 535 Times in 110 Posts
If you want something fairly lightweight, I've used Braille B3121 batteries (21 lbs.) with good luck. I try to swap batteries every 3-4 yrs.
Jim Kaekel 3836 STK |
Liked 510 Times in 117 Posts
I've used the oddesy batteries with never an issue. Finally replaced it this year only because it was 5 years old. Never let me down.
68 Chevy11 327 F/S |
Liked 279 Times in 68 Posts
I also have had good luck with the Odyssey batteries. We use two of the 925's.
Greg Hill 4171 STK |
Liked 484 Times in 160 Posts
Optima yellow top any good for drag racing ? I saw one in the Fletch's stocker wagon @ Indy.
Optima yellow tops work great since they are a deep cycle battery. However, you also need a charger made for this type of battery. Sears makes one and I think Optima also has one.
Liked 24 Times in 13 Posts
Optima Red tops is what I use - never let me down.
Jeff Dudgeon '66 Coronet #10771 - bracket puke "the Flying Brick" |
Liked 71 Times in 38 Posts
I've run an Optima yellow top for years. One of the best batteries I've tried, albeit somewhat heavy. It may have been wrong, but I always used a standard charger on it. Never had a problem.
Liked 56 Times in 27 Posts
Chuck, You have a PM...........
Dave Ribeiro 1033 STK |
