Old 12-18-2013, 08:52 PM   #41
gbur
Default Re: Pure Stockers New Camshaft Rule !!!
Here are the emails back and forth from Mike last night!
Sent: Tuesday, December 17, 2013 3:33 PM
To: Daniel Fahey
Subject: Re: Pure Stock Spring VS574 - Checking for Legality
Yes
Sent from my Verizon Wireless 4G LTE DROID
Daniel Fahey wrote:
So if the Spring Pressure is 30% above Stock it will be OK?
Just so long as it is a Stock Replacement Spring!
Correct?
D
Daniel Fahey - CEO President
DanSources Technical Services, Inc.
1010 Rockville Pike, Suite 405
Rockville, MD 20852
301-217-0425 x 400
www.DanSources.com
Sent: Tuesday, December 17, 2013 3:25 PM
To: Daniel Fahey
If it is oem design and size it is ok
Daniel Fahey wrote:
Hello Mike:
Called Bullet Cams for advice…
He asked me to confirm on my LT1 1995 SBC Engine.
My Car runs G/Pure Stock. 1995 Impala SS.
Looking at a replacement spring from Associated Spring VS574..
Lists as a LT-1 replacement spring.
Need to know if it qualifies as a Pure Stock Legal Spring for my car.
Dan
Rockville, MD 20852
301-217-0425 x 400
www.DanSources.com
Just how are you the only one that gets a response from Mike Baker. Maybe in his pocket somehow ?
gbur is offline   Reply With Quote
Old 12-18-2013, 08:54 PM   #42
gbur
Originally Posted by Tar Heel View Post
No, we were legal. It still has the oxygen sensors so we have to run unleaded.
Scott
your previous post is still on here that you bought gas from the fuel guy at the track , just on a different thread
Old 12-18-2013, 08:56 PM   #43
gbur
Just so everyone understands. I am a straight up guy and say as I see it
Old 12-18-2013, 09:59 PM   #44
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I agree that this rule hurts the Intent of Pure Stock.
Having mixed opinion because the original rule was working to bring more cars in to Stock as a Pure Stocker.
Just wondering why this topic was not discussed.
The old rules were working just fine.
Not a lot of us but enough to make the Class interesting.
Drawing in the new cars and Racers interested in giving Class Racing a crack.
That was the intent of Pure Stock.
As for getting the ear of Mike.
Yes...he likes working with me.
Likes the fact of supporting Pure Stock and being an advocate of IHRA racing.
I was making a difference and attracting folks getting interested in Class Racing.
I post on IHRA blogg on LinkedIn.
In the interest of speeding up a detailed tech inspection of a cam.
I get that.
Just think there were other ways to to speed up that process.
Such as having the CamManufacturer declare the Cam was built to the intent of the Rules.
Reputation means everything to a Manufacturer.
A Cam Card Certified. Have it sent to an IHRA Tech person to measure it.
Understand the Reffing part very well.
How can the processes be designed so the Tech Inspection is quick and thorough?
Made a suggestion to have Centers and Dates set up between races just for Tech Inspection.
Meet in mass prepared and assisting the Inspectors.
The number of IHRA National Records set is pathetic compared to NHRA.
More cars Teched will take the National Record challenge.
Other ideas need to collaborated with Racers.
This was a bit of a shocker.
Bottom line..
How can we make IHRA Better for every one than NHRA ?
Dan
Old 12-18-2013, 10:35 PM   #45
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Originally Posted by gbur View Post
Well said. IHRA needs to revert this rule now. As I said earlier, oem cam and springs. So whats next,roller rockers,and the list could go on. KEEP IT SIMPLE
LOL
Don't forget the Kirkey seats as well.
Seriously, I believe this could be the deathblow to PS.
What a shame.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-19-2013, 02:25 AM   #46
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
IHRA may be ahead of the curve.......
NHRA has just accepted the 2010. 2012, and 2013 Mustang GT (showroom available) into the Classification guide. 227 V6, 4.6 (281)V8, and the 5.0 (302)V8 in different years. IHRA, we can assume will follow suit and accept these also for Stock / Pure Stock. Now the fun begins, DOHC cams 3 or 4 valve per cyl, separate cams for int and ex in each head. Independent Variable valve (cam) timing, the overlap can be in a range of -51 to +49 @.050 depending on what the phasers are doing at a given RPM or in the park (off) position.... A potential Tech Man's Pure Stock nightmare ? or just check lift at the retainer and done, and, 32 itty bitty beehive springs buried under all that OHC stuff...
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is online now   Reply With Quote
Old 12-19-2013, 04:09 AM   #47
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
On principal it's good to see production cars in the guide for a change. But, the 5.0 and 4.6 factoring is way worse than the 5.0 and 4.6 CJs are. Same car, so might as well run the CJ combo. V6 doesn't look good either, and not many would be interested in running one anyway.
kdanner is offline   Reply With Quote
Old 12-19-2013, 08:34 AM   #48
ALMACK
ALMACK's Avatar
^^ agree
The V-6 is rated at 260 h.p.....a bit too high. Should have been 230 hp.
Without much aftermarket support for the 3.7, I doubt we will see this combo used much.
Has to be 3550 lbs raceweight and run on a 12.65 index in K/SA.
It will take at least 350 fwhp to do it according to the Wallace calculator.
The 2010 4.6 GT engine is a bit high @ 270 hp compared to the same year 4.6 CJ at 272 h.p.....and that 2 h.p. more gets you cnc ported heads, twin 62 mm throttle body, bigger cams, and probably more compression.
The Coyote 5.0 is way off the mark at 380 h.p.
That's too bad.
I/PS '95 Mustang GT
Old 12-19-2013, 09:11 AM   #49
Tar Heel
Guest
Posts: n/a
Yes, we bought unleaded gas at the track that is on the list of approved fuels for Stock on the IHRA web site. Also, that was when we were test and tuning late in the summer. That fuel is gone and before we raced in Dallas Thanksgiving weekend we stopped at a gas station for good 'ol 93 octane pump gas.
Scott
Old 12-19-2013, 10:04 AM   #50
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
I have mixed opinions on cam/spring rule.
There is probaly 3 factors for this decision,1 is speeds up tech,2 is many newer cars there aren't duration,overlap,spring specs.3 is not up to me to comment on,I'll just say someone loaned out some information and the borrower does'nt seem to want to return it for some reason
I don't really like it but I will be changing my cam,valve springs,then probaly gearing in trans and rear and last but not least I'll be adding about 800-1200 rpm.
I do like that will be able to run under K/S index in NHRA now instead of a little above,so will be able to run @ Bowling Green now without having to finish new engine.
As far as driving pure stockers,later model cars were still drivable,but my older combo I could barely run under and be drivable,so drivability was gone for me along time ago,plus if could drive would still haul I don't like walking home.
Mike Taylor 3601
