Old 01-19-2014, 12:49 PM   #26
Nathan Stinson
Nathan Stinson's Avatar
Liked 4 Times in 1 Post
Default Re: Are synthetic oils and lubricants any quicker
Originally Posted by buzzinhalfdozen View Post
A call to any reputable company will confirm that running an aluminum spool decreases gear life, this is "fact and truth" you're 2 favorite things, heavy cars, above 2800 lbs. according to Mark Williams they DO NOT recommend aluminum spools....why?
I know this question is kind of off topic from the OP's question but I would like to get some more input on this item. I have ran aluminum spools for several years with no problems at 3000 lbs. I am assuming that the reason it is hard on gears with the heavier weight is that the spool can flex enough to change the contact pattern on the gear? I am changing combos this year and will now have to weigh 3400lbs and wondering if it would be better to switch back to a steel spool? What would be better gear life or accelerating the steel spool? How many runs before the gear starts to go away with the aluminum spool at that weight?
Nathan Stinson is offline   Reply With Quote
