Old 01-19-2014, 06:19 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: Clutch sensor
The old collar must be removed. Looking at a source ( Ruland) that makes a variety of sizes. Likely need to find one that is close ( ID and OD) and hone the ID or turn the OD to make it work. Needs to be 2.350 OD , 1.750 ID .
John Nechiporchik is offline   Reply With Quote
Old 01-20-2014, 12:32 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
John,
It looks like Grainger and IBT has 1.75" ID in a 2 piece. But the OD is 2.75" But you need an OD of 2.38. The last one of the list is 1 5/8" ID and 2 3/8" OD. That might work if you can machine the ID to what you need.
Sean
http://www.grainger.com/product/RULA...UZ2?s_pp=false
https://www.shopibt.com/storefront/i...&itm_index=270
https://www.shopibt.com/storefront/i...&itm_index=292
Sean Marconette
84 Mustang
5060 SS/N
Old 01-20-2014, 02:41 PM   #3
John Nechiporchik
Thanks for your help Sean.
The Ruland line has an aluminum unit (SP-25-A) that is 2.375 OD (good) and 1.5625 ID that I can make work.
I got a few feelers out now to see if anyone has one already made up for this application. If I don't get lucky soon....I'll try the Ruland. The local Motion Industries store can get it for me in a few days....$18 for aluminum. Then I need to drill it for the magnets....get them from racepak...and hopefully be done with this project!!!!
PM me if you want to chat about this stick stuff. I'm on a learning curve and need all the help I can get!!
John
