Old 02-04-2014, 05:07 PM   #1
Run to Rund
Liked 55 Times in 28 Posts
Default Re: transfer tanks/towing
I also use Transfer Flow, and highly recommend them. Back in the 90s I used a W---gard tank. It cracked and rusted so I went through a lot of fuel filters before giving up on it.
Old 02-05-2014, 05:09 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: transfer tanks/towing
Darn, too bad I didn't know because I coulda showed you the 60 gal. w/tool box I have in my dually. It's under my topper, but I switched the sliding window around so I can open it at the front and fill the tank through it. But the window does leak some when it rains. I've also seen some set-ups where the filler cap is built into the side of the topper. It's made by RDS which are sold by Northern Tools. I got mine at a local truck supply store.
It is gravity feed with a shut-off valve. I believe I read somewhere that you are not suppose to keep it open while on the road per DOT regs. Hope someone can clarify. But I open it at the track and it refills the main tank there.
It's great to be able to skip through the higher fuel price states!
LOCOMOTION Racing
Old 02-06-2014, 11:04 AM   #3
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Anyone know, for sure, can you do this w/ gas, or only diesel ? I've heard yes's and no's.
2894 STK
Old 02-06-2014, 11:30 AM   #4
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
this is a nice one
http://www.ebay.com/itm/DeeZee-DZ-91...-/261390900179
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 02-06-2014, 08:20 PM   #5
mike britt
Liked 66 Times in 31 Posts
If you try this on a gas truck, you'll probably end up with evap. emission problems unless you use a shut off valve and turn it off when the ECM is monitoring evap.
mike britt is offline   Reply With Quote
Old 02-09-2014, 05:06 PM   #6
Rob Petrie E395
Liked 216 Times in 77 Posts
I have a transfer tank in a Gas truck. I put a electric pump out of a Tbi pickup in mine and ran the line to the top of the tank. Through a fitting that I welded into the tank.. And then down to the filler neck with a fitting welded on there as well. If you keep a couple of gallons in the tranfer tank and don't run it dry. It will still hold enough pressure to keep from kicking a CEL for evap. emmissions. Nice part is I can run down the road and flip a switch to fill it up and not have to stop to transfer fuel.
Old 02-09-2014, 06:02 PM   #7
Ed Wright
Ed Wright's Avatar
EVAP codes can be fixed.
Ed Wright 4156 SS/JA
Old 02-09-2014, 06:52 PM   #8
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I could not stand to drive that long without stopping.
Rich Taylor
I/SA - 321
