this winter i plan to build a pure stock elinimator nova. i was woundering what gear ratios i should go with in the trans and rear? heres some info on my car. if you need more please ask.
engine-350 2 or 4 barrel; 390/410 195/202@050 800-4800 trans-350 turbo rear-8.5 10-bolt weight-3214 (thats shipping weight) tires-28-29.5x9x15 bias ply or radial i dont know yet which is the best for my combination. |
Liked 66 Times in 37 Posts
Is this a 69 or 70? It matters on the 2 Barrel combo - which is a good combo.
Gear as tight as you can unless your driving it in - then 4.11 is about max on the freeway. |
Liked 33 Times in 15 Posts
You may want to check with IHRA on your cam specs. You may be pleasantly surprised by the duration numbers. I would also get the valve spring pressure from them as this was my limiting factor when I ran Pure Stock. When you get these figures, it will be easier to choose a convertor and gearing.
Good Luck, Joe
Joe Marcinowski 3377 STK |
its a 73. i will ask for the spring numbers. im trying to find tranny gears and rear gears to run. i know they are out there, im just not sure as to which one. thanks for the help so far.
Liked 13 Times in 9 Posts
I'm putting new 'shoes' on the car at Rockingham. Might not be a lot left on them, but you can try my 9x29.5 M/T radials then. Radials must certainly be the ticket for a Pure Stocker!
furr980,
Join this group, http://sports.groups.yahoo.com/group...OCKdragracing/. You'll get plenty of help from these guys. The 29.5 Mickey T radials were a .10 faster on my Pure Stocker in a back to back. Later, Joe
Liked 209 Times in 46 Posts
I would put a 2.75 gear in the trans and a 4.88 in the rear running radials. You might want to check cam specs on the 73 and 74 . One had a optional calif cam with more duration,401/401 lift, if available I would use the 4bbl.
Liked 81 Times in 35 Posts
8.5 10 bolt >>>>>>>>>> you will be limited to a 4.11 I believe.
Greg |
thanks guys for all the great info. thnaks michael for the radials, ill defineatelt be testing with them. mark, where can i find that optional cam you were refering to.
Liked 5 Times in 3 Posts
the 74 is the one that has the 401 cam....also an 8.5 rearend will be fine in a pure stocker...you can get up to a 5.38 ring & pinion.....my cutlass has an 8.5 with a 5.13 gear & i've turned as good as 1.61 60's with it.
