Liked 33 Times in 16 Posts
As I'm just starting a O/SA build I would like to hear about these things as well since I have zero experience with the Fords Charlie.
I've been eyeballing the Maximum Motorsports adjustable lowers...thinking it might be handy to be able set ride height with the springs. I really have no clue as to whether it would be beneficial tho...I have not even decided between 26" or 28" tires. Does a rear sway bar make much difference in these Mustangs at these power levels? I was thinking any adjustable upper control arm would be fine, but again I am just guessing at this point. You use these to set pinion angle, right?
Rich Taylor I/SA - 321 |
Liked 370 Times in 101 Posts
Lower control arms cannot be adjustable. Global West makes a nice lower, and the uppers can be adjustable, Team Z, Wild Rides, and UPR have nice ones.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 12 Times in 4 Posts
We've used the UPR ones on so many different class Mustangs with great results. I'm currently gathering parts for my Fox body stocker and it will wear UPR rear suspension components.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
Liked 227 Times in 74 Posts
Here is my take on this subject. For rear suspension double adjustable uppers everybody makes them, both upper and lower needs to have spherical in all joints, this will make your rear suspension very free when this happens you will need to do some thing like a sway bar or others use air bags to help this. Finding lower arms with spherical bearing in both ends is rare I think BMR makes some.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#5 | |
#6 | |
A couple of rings of soft rubber on the outside and ..ah never mind...I didn't say it.
#8 | |
By adjustable I meant the spring perches, not in length. Would these be legal? Are you guys using a sway bar on the rear?
Rich Taylor I/SA - 321 Last edited by HandOverFist; 10-23-2014 at 10:03 AM. |
we are usin adj uppers but lakewood traction action lowers . so far works great
