Old 01-03-2015, 01:24 PM   #31
Bill Harris
Liked 26 Times in 13 Posts
Default Re: 2015 Mustang Revealed
Originally Posted by ALMACK View Post
If that 2.3 EB Mustand ever does make it into the classification guide, I would imagine it would be a K or L combo.
Ford spec weight for the Ecoboost fastback automatic is 3524 lbs. If the 2.3L turbo 4 were to go into the guide and NHRA follows their usual way of starting with the NHRA HP = Factory HP then the weight break is 11.37, or a natural G with a 12.0 index, so it is already under that with the Livernois setup.
Wonder if the IRS in the new Mustang uses the same ring and pinion as the Ford 8.8? If it is a completely new differential it's going to be tough to get a serious drag race ratio for it.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 01-03-2015, 01:32 PM   #32
rawhide
Liked 7 Times in 5 Posts
Ford Racing shows a different part number for the 2015 gears. The only ratio's that they show at this time is 3.55 and 3.73. Neither is available as of this time and my back order list shows an available date of 1-15-15.
The following is their description:
  • Fits 2015 Mustang GT 8.8-inch IRS center section
  • Requires M-4210-B3 2015 Mustang GT 8.8-inch ring-gear and pinion install kit
  • Made in United States in Ford's Sterling Axle Plant
  • OEM Quality - our superior surface finish, hardening and manufacturing consistency provide the strongest and quietest gears in the market.
Roland
rawhide is offline   Reply With Quote
Old 01-03-2015, 06:38 PM   #33
goinbroke2
Liked 405 Times in 158 Posts
It's the 8.8 irs same as the explorer or navigator or whichever one uses it. Regardless, wouldn't it be the same as swapping out the irs on the vette? The 2.3eco is one thing, what happens when somebody runs a coyote or the new 5.2 in the gt-350? That 5.2 is readlined at 8000 from the factory! Flat crank, forged everything, blah, blah, blah...I'm guessing dropping the clutch at 7K with slicks should throw u-joints quite far!
edit: Something else I noticed on the video, notice how it sucks the rear down as he's torquing it up? Modifying angles for straightline only should really improve an already awesome package.
Old 01-04-2015, 08:37 AM   #34
rocknrolla
rocknrolla's Avatar
I hope to see the new Mustang at the track this year. The 2.3 L EcoBoost I4 looks impressive. Here is my Super Stock/Comp photochop.
rocknrolla is offline   Reply With Quote
Old 01-04-2015, 10:53 AM   #35
Glenn Briglio
Glenn Briglio's Avatar
Liked 977 Times in 312 Posts
Originally Posted by fred goodwin View Post
Evan,I liked the story so much I went out and bought one!
Stick or auto Fred? Yeah I"ve been looking at buying one too!!!!
Old 01-04-2015, 11:13 AM   #36
Jerry Davis
Liked 10 Times in 6 Posts
My wife Sue has ordered one with the Ecoboost from Fred Henson should be in around the middle of the month.
Jerry Davis 4168 STK
Jerry Davis is offline   Reply With Quote
Old 01-04-2015, 02:28 PM   #37
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Ford Racing is already working on the solid axle conversion.
I didn't keep the link, but a little while back I saw where they were working on a kit.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 01-04-2015, 06:45 PM   #38
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
automatic glenn,my wife is the main driver soooooooooo the 6 speed stick was shot down right away!
Name:	turbo mustang.jpg
fred goodwin is offline   Reply With Quote
Old 01-04-2015, 07:40 PM   #39
ALMACK
ALMACK's Avatar
Good choice on the trans Fred.
I like those wheels better than the "blacked out" versions.
I/PS '95 Mustang GT
Old 01-04-2015, 07:56 PM   #40
Liked 17,627 Times in 1,602 Posts
Just picked up my new "EcoBeast" F/S combo.
ID:	26761   Click image for larger version
ID:	26762   Click image for larger version
