#71 | |
Liked 7,813 Times in 1,748 Posts
#72 |
Liked 154 Times in 37 Posts
Thank you ! Mr. Southerland
66W30POST |
#73 | |
Liked 1,603 Times in 583 Posts
#74 |
Liked 370 Times in 101 Posts
Exactly, Dwight !!!!!!!!!!!!
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#75 |
Liked 184 Times in 113 Posts
Thanks Dwight.
I am not having valve train fracture problems in Pure Stock. Basically early Stock rules. IMHO be a good idea to moderate the spring rule. Get back to a NTE rating. NASCAR cams are a different breed. Stocker cams are physically smaller. Shorter lift and massive duration never intended. 150 lb closed and 400 open is a good start. Some ratio for Valve size. Just putting it out there. D |
#76 |
Liked 308 Times in 103 Posts
I agree if stock pressure spring rule was left alone in 87 wouldn't need tool steel,ceramic lifters and everything that came after that,was just putting out there the effects of not having the spring pressure to control the valvetrain, if you want to run the aggressive lobes and crank up the RPM then you have to have the spring pressure.
The stockers I build have plenty of spring pressure,they make more runs and require less maintenance than my pure stocker with stock spring pressure does,there valves,guides,spings,valve jobs will last twice as many runs as my pure stocker does.. Mike Taylor 3601 |
#77 | |
Liked 780 Times in 194 Posts
![]() Last edited by Dwight Southerland; 10-23-2015 at 12:17 PM. |
#78 |
Hmmm interesting..
Moderating Spring Pressure is a good answer. I like racing..not fixing broken stuff. Using super high springs pressure creates larger catastrophic messes. Someone mentioned they could not even get it off the Dyno. Then required a new rotating assembly. This does not happen anywhere often with Bracket Engines. xHRA's need consider this. Especially the RIO.. Fewer breakdowns during qualifying and competition. D |
#79 |
Liked 9 Times in 8 Posts
If you have canted heads with 120+ gram valves and crooked pushrods you are going to need valve springs....you inline valve guys with tiny valves and straight pushrod geometry should never break a dam thing.
Its as simple as that 1 spring rule for everybody is not a cure all.... guys that race,.not bracket race the combo will always push the limit watch how much "breakage" Prostock is going to have with a 10,500 rpm limit...should have left that alone also
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 10-23-2015 at 01:33 PM. |
#80 |
Dwight,
I didn't take your post as confrontation or picking on me. Mike Taylor 3601 |
