Old 12-29-2015, 03:25 PM   #1
bpete
Liked 19 Times in 4 Posts
Default N/S Bell housing requirement?
Is a SFI Bell housing, Clutch and Flywheel required for N/S
If I read the version of the rule book I have correctly (2013 pdf version)….
For N/S or Slower
No roll bar required
Factory Seat belts acceptable.
Drive Shaft loop - required
SFI bell Housing, Clutch, and Flywheel required?
Application is a 1995 Mustang GT Coupe 5 speed .
Should fit into M ,N or O at 215 hp according to ClassRacerInfo
I love that site, by the way!
Thanks,
Brad
bpete is offline   Reply With Quote
Old 12-29-2015, 03:32 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 506 Times in 116 Posts
Default Re: N/S Bell housing requirement?
SFI shield and clutch components are required.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 12-29-2015, 03:36 PM   #3
Bob Don
Bob Don's Avatar
Liked 900 Times in 191 Posts
CLUTCH, FLYWHEEL, FLYWHEEL SHIELD
Clutch and flywheel meeting SFI Spec 1.1 or 1.2 (2-disc maximum) mandatory. Steel flywheel shield meeting SFI Spec 6.1 mandatory on all V-8 cars with a clutch. Flywheel shield cannot be modified for clutch adjustment and/or cooling holes. See General Regulations 2:3, 2:5, 2:6, 2:10.
Bob Don 128 SS
Old 12-29-2015, 04:14 PM   #4
bpete
Thanks for confirming.
I understand the reasons for good quality components in the clutch department.
I found it a bit odd that factory seat belts were still allowed but SFI bell housings, clutch and flywheel are required.
I’m not sure I understand allowing factory belts and no roll bars if you’re going to require SFI bell housing and clutch parts.
Brad
Old 12-29-2015, 05:46 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,926 Times in 579 Posts
Brad
You would be best off with a good roll bar and harness. That's a hold over from years back when a N/S car was no where near as fast as they are now. Plus you might be paired up with an 8 second car in the other lane at some point.
Mike Pearson 2485 SS
Old 12-29-2015, 07:30 PM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
X2
Mike Taylor 3601
Old 12-29-2015, 09:03 PM   #7
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
It's an RPM thing. Those "low HP combos" can still wind up pretty high. Especially a clutch car. There are 4 cylinders in SS winding 9K.
And do get a 5 point harness and roll bar. You can't put it in after you get run over by a 150 mph car.
Dale
Dale Shearon
68 Mustang 6394
