Old 03-29-2016, 02:51 PM   #17
joespanova
Liked 13 Times in 11 Posts
Default Re: A follow up to "oil starvation issues" thread
Glad you caught it before things turned into shrapnel. Amazing how the rod brgs. look perfect and the mains are hammered. Aeration, too much oil upstairs, an internal leak...likely a combination of things. Are you going to change where you source the vacuum or eliminate the pump all together?
I am reducing vac to , say , 6-7in , adding a balance tube to opposite side. I'll still pull off valve cover.
