#11 | |
Liked 140 Times in 46 Posts
Someone mentioned holding the pilot while spinning it. You may have to bump it with the butt of your hand while it's spinning to get it to seat. Get a little dab of tans gel and dab a little around the snout of the converter by the pump lugs.
Jon Sarrett Stock 3779 |
#12 | |
Liked 5,147 Times in 1,964 Posts
Of course if you don't build trannys , you wouldn't have trans gel laying around. You might want to take some white lube and fill the pump slots in the hub and paint a couple of splines on the input shaft and on the stator support, and then try the converter as far as you can , with palm pressure only. You should be able to see an impression of just what's causing the hang up.
#13 |
Lesson I learned the hard way, if the converter is fully engaged you shouldn't be able to run your fingers behind it unless you have small fingers. I'm not judging anyone by the size of their fingers that's the politicians job.....
#14 |
Liked 886 Times in 238 Posts
I've installed several TurboAction Metrics that did not have the pilot snout that is used for the factory lock up converter cut off and prevented the converter from fully entering the pump.
Some converters will accept the snout , others will not. If yours has the snout that is likely the problem.
#15 |
Well, Tom Goldman turned me on to my problem. It was the pilot snout on later lock-up converter transmissions. Cut it off and problem solved, almost.
Still had trouble getting it on all the way. So, I took Mike Delahanty's advice and stood the trans upright. Didn't have a garbage can handy, so I used the cherrypicker. Worked like a charm. I thank everybody that responded. That's what's great about this site. Everytime I get hung up on something, the answer is always here.
Bobby & Norene Zlatkin L/SA |
#16 | |
You can hack saw that thing off or use a cut off wheel, but unless you want to disassemble the front half , I would stick a Q tip with some grease on it in the hole first. Leave it sticking out, and cut it along with the nub. Then just grab it and pull it out, chips and all.
